Delteq Opti replacement
Old Apr 25, 2004 | 10:52 PM
  #16
Totsabe's Avatar
The design flaw of the optispark was only the high voltage side. The optical sensors and encoder wheel are as close to bullet proof as you can get.
I removed the front half of my optispark years ago and sealed the rear chamber. You can also just pull the spark plug wires off and leave it there. The automatics still use the hi/lo rez signals for shifting.
The Opticrap legend is also exagerated with the aftermarket MSD boxes that increase the voltage through the distributor.
The Delteq company is going for the heart of the problem of LT1's. It is the perfect cure for the Optispark.
Good Luck
Old Apr 26, 2004 | 07:10 AM
  #17
schpenxel's Avatar
I've gotten the "low res pulse error" code a few times, the optical side isn't bulletproof, however it is more reliable than the other side. If the bearings were higher quality, the optical side would probably be bullet proof. They tend to rust, and obviously rust+optical sensors doesn't work out too well. I'd rather just get rid of the whole damn'd thing
Carson
Good Luck
Old Apr 26, 2004 | 08:09 AM
  #18
magius231's Avatar
I dunno...out of the 2 T/A's I have had I have yet to have an opti fail on me, and if it does its less than $200 to replace...so I could buy 3 opti's for what all these other systems are costing me...
BTW the first car had 79k miles and this one has 72k miles...all on the original opti...
Old Apr 26, 2004 | 09:16 AM
  #19
schpenxel's Avatar
You are a lucky soul
A friend of mine just bought a T/A, it runs good but has a slight miss, so he's replacing the opti. It'd probably last a lot longer, but isn't running quite right, not sure if you would have noticed any improvement had you replaced the opti anyways, but its definetly possible. Many people have reported their cars running better than ever before after replacing an opti.
Carson
Old May 14, 2004 | 02:22 PM
  #20
Kris96WS6's Avatar
Delteq GP
There is a thread in the GP section checking for interst in the Delteq GP....
http://web.camaross.com/forums/showt...22#post2143122
Old May 14, 2004 | 03:23 PM
  #21
Super Slow '97's Avatar
Do a search for LTCC or DELTEQ there are many threads about this there is a lot of information about these two items. The threads are very thorough check the advanced tech section.
Old May 18, 2004 | 11:18 PM
  #22
I1O0O1I's Avatar
And Im sure your just making GOBS of power with those major mods you have in your sig to even make an opti even want to break That's great that your car is pretty much stock and slow but some people that have 12 & under cars need something better than stock
Old May 19, 2004 | 01:06 AM
  #23
ZBLKHELLRZR's Avatar
93 w/ stk opti on it still in my 396. Has about 65K on it but I'm heading to VA. next month and will be picking on up and carrying it w/ me on the plane back!
Old May 19, 2004 | 02:15 AM
  #24
Timecr0ss's Avatar
That's great man, but my logic is as follows:
I have the money to greatly decrease the chances of the opti killing my car or causing problems. So since I need to replace my opti, I'd rather just upgrade this once and get it done with.
Also, I've read the DELTEQ offers a stronger spark. Interesting stuff.
Old May 19, 2004 | 03:58 PM
  #25
Maldo's Avatar
Hi guys for those who are interested i am having a GP on the delteg Below are the links.
http://web.camaross.com/forums/showt...hreadid=260824
http://web.camaross.com/forums/showt...hreadid=263358
or you can view the prices at http://www.elitesparkplugs.com
grabbem88
Mar 18, 2015 01:25 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Ari G
Dec 11, 2014 03:21 PM
pologreen97z
Dec 2, 2014 10:42 AM
