Delteq Opti-direct
Old Apr 26, 2004 | 12:06 AM
Camaroz28lt1383's Avatar
Delteq Opti-direct
I was wondering where delteq gets the coil packs, like do they get them from another car, cause i know the 3800 series motors use coils like that, but of course 2 less. Thanks for your reply Paul
Old Apr 26, 2004 | 12:10 AM
Dave88LX's Avatar
Cadillac Northstar, and Olds Aurora V-8's.
I got my 4 coil-packs + ignition module off of ebay for $120. Saves you a bit of money that way.
Old Apr 26, 2004 | 01:37 AM
Alex94TAGT's Avatar
Actually, the 3800 would have one less coil -- not two less coils. Each coil powers two cylinders, four coils in total (not like the LTCC 'coil-per-cylinder' setup).
From what I've found, these are the generic Northstar coil part numbers (four needed). Not sure if they are 100% accurate -- USE AT YOUR OWN RISK!!!:
AC DELCO: D555
BECK/ARNLEY: 178-8206
WELLS: C849
GP SORENSEN: GC411
STANDARD: DR39
SUMMIT RACING: SUM-850017
NAPA/ECHLIN: IC406
And these are the generic Northstar Ignition Control Modules (one needed):
AC DELCO: D1980-A
BORG WARNER: CBE43
WELLS: DR160
GP SORENSEN: EL189
STANDARD: LX362
NAPA/ECHLIN: TP415
*If anyone can verify those part numbers, that'd be great.*
I saw that Summit now sells a higher-output, dual-post GM DIS coil (part number SUM-850017 listed above ~ $33 each). Looks like you can pick up one of the Wells C849 coils for about $19 each from Autozone. Of course, you'll still need the Northstar ignition control module that the four coils sit on, which is the most expensive.
tommalcolm
Sep 11, 2015 03:39 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Maldo
259
Feb 22, 2005 10:14 PM
transamdude95
Sep 4, 2004 11:28 PM
