delteq or ltcc
Old May 24, 2004 | 11:17 AM
  #16
IDOXLR8's Avatar
Originally posted by duckhead4life
anybody knows if any of these systems will work with the fast system i am curious about this one my self.
I am running one with my FAST system.
Old May 25, 2004 | 04:16 AM
  #17
duckhead4life's Avatar
what about the delteq. becasue there is a gp going on. and i definately wont to get in on it but i need to know if it is capatible with the delteq. somebody has to know.
Old Jul 19, 2004 | 03:51 PM
  #18
94Zpower's Avatar
Re: delteq or ltcc
Is that MSD box the only box that can be used with the delteq?? if so why??
I have a Mallory HY Fire 685 and I really dont want to sell it because its brand new!!
Old Jul 19, 2004 | 07:28 PM
  #19
mtxpert's Avatar
Re: delteq or ltcc
You can't use the 685 with either ignition system...
Mike
Old Jul 19, 2004 | 10:45 PM
  #20
CDE's Avatar
CDE
Re: delteq or ltcc
I allready have a MSD Dig-6 for my Nitrous retard. Is that ok to use instead of the Dig-4? So I would be better off going with the LTCC setup right?
Old Jul 19, 2004 | 11:17 PM
  #21
bunker's Avatar
Re: delteq or ltcc
I'd go with LTCC, I'm a happy owner of one, plus I can't have a delteq because is fires 2 cylinders at once one on the exhaust stroke, I run my car pretty rich for drivability reasons I find it best that way so if I had an ignition system that was firing at the exhaust stroke it would probably light the mixture again LOL
Old Jul 19, 2004 | 11:42 PM
  #22
mtxpert's Avatar
Re: delteq or ltcc
You can not use any ignition box with the LTCC, you can ONLY use the DIS-4 for the Delteq setup.
Mike
Old Jul 20, 2004 | 12:29 AM
  #23
disco192's Avatar
Re: delteq or ltcc
I have the delteq system and i also have a Accel 300+ ignition. So there isnt any way to run that with it? Would it be worth it to run the ignition? Just curious.
Old Jul 20, 2004 | 03:44 AM
  #24
ZBLKHELLRZR's Avatar
Re: delteq or ltcc
Can't use the 300 + it's one ignition system or the other. I'm replacing my 300+ as well but just in case my delteq gives me headaches I'll put the old setup back on.
Old Jul 20, 2004 | 08:53 AM
  #25
mtxpert's Avatar
Re: delteq or ltcc
Let's be REALLY CLEAR about this.
You CAN'T USE ANY ignition box with either system with the one exception of the DIS-4 from MSD with the Delteq.
I hope that explains it well enough.
Mike
Old Jul 20, 2004 | 10:02 AM
  #26
Mystic95Z's Avatar
Re: delteq or ltcc
I put my LTCC on about a week ago and it's worked flawlessly, plus my MPG has picked up considerably. Last tank I got 250 miles out of a tank, before the LTCC I only got 190-200 and that was with a opti, plugs & wires change last August. Definatly worth IMHO and it'll be nice to have once I go FI.
-Tony
Old Jul 20, 2004 | 11:38 AM
  #27
94Zpower's Avatar
Re: delteq or ltcc
Mike
I understand what u are saying but could u explain why?? just for my own knowledge I would like to know.
Thanks!
Old Jul 20, 2004 | 06:57 PM
  #28
mtxpert's Avatar
Re: delteq or ltcc
The ignition boxes won't interface with a multi coil setup. The DIS-4 will work with a 4 coil setup but not an 8. The regular ignitions are all made for a single coil interface.
Mike
Old Jul 21, 2004 | 07:02 AM
  #29
94Zpower's Avatar
Re: delteq or ltcc
so the 685 box will not work on an LS1 car either??
Old Jul 21, 2004 | 08:53 AM
  #30
mtxpert's Avatar
Re: delteq or ltcc
No...
Mike
