deleting o2 sensors
Old Apr 3, 2006 | 09:25 PM
sw89lt1's Avatar
deleting o2 sensors
i'm redoing my wiring harness getting rid of all the bs and i'm thinking about getting rid of my o2 sensors and maybe my iat sensor. are there any long term effects besides bad fuel economy? is this a bad idea?
this will be a weekend car only.
Old Apr 3, 2006 | 10:37 PM
Re: deleting o2 sensors
Yeah, it's a bad idea.
Old Apr 3, 2006 | 10:41 PM
sw89lt1's Avatar
which one i haven't had the o2s hooked up for a while.
Old Apr 3, 2006 | 10:46 PM
Both
Old Apr 3, 2006 | 10:55 PM
Javier97Z28's Avatar
Moderator
Are you running in open loop at all times? If so, why?
Or have you converted to speed density?
Leave your IAT in.
Old Apr 3, 2006 | 10:59 PM
sw89lt1's Avatar
yes because i have an exhaust leak.
Old Apr 3, 2006 | 11:03 PM
Moderator
Fix your exhaust leak, don't eliminate the sensors.
The computer needs all it's sensor inputs to accurately control the engine. Why don't you just fix your car?
Old Apr 3, 2006 | 11:05 PM
Amazing... the critical sensors are not "BS".... they help the car make max power, without the potential for engine damage, help maximize fuel mileage and eliminate fouled plugs, and allow the PCM to compensate for changes in ambient conditions and even significant mods to the engine. Fix the exhaust leak, insure the O2 sensors and IAT sensor are functioning correctly, and enjoy the benefits of a modern, computer controlled fuel injection system.
Old Apr 4, 2006 | 07:27 PM
sw89lt1's Avatar
by bs i meant a/c, egr, evap.
thanx for the help.
Old Apr 4, 2006 | 08:10 PM
96capricemgr's Avatar
Injection is a huge part of why engines these days do not exhibit the wear older ones did. This is largely due to better AFR control at all temps and throttle. Without O2s you will likely run either rich or lean, rich will carbon up and wash away the oil on the walls accelerating engine wear lean is at best a bad thing.
stylin99
Feb 3, 2016 02:24 PM
guest74777
Mar 25, 2015 10:30 AM
alex5366
Mar 8, 2015 11:32 AM
ssfirefighter
Aug 17, 2002 03:19 PM
