Deleting EVAP
Old Jul 29, 2004 | 04:04 PM
SS1304's Avatar
Deleting EVAP
If I had it tuned out of my computer can I take it out of my motor adn crap to clean it up?
Old Jul 29, 2004 | 04:06 PM
Re: Deleting EVAP
I would suggest leaving it, unless you like to breath gas fumes.
Old Jul 29, 2004 | 05:28 PM
SS1304's Avatar
Re: Deleting EVAP
It doesn't work as it is
It was throwing a code that I have been trying to track down for a LONG time and could never get it fixed. So when I had my car tuned I had it taken out of the PCM
Old Jul 29, 2004 | 06:48 PM
PatriotTA's Avatar
Re: Deleting EVAP
Everyone told me not to do it, but I did it anyway, and there are no problems, and there aren't any bad gas fumes. You can smell it sometimes when you are just sitting in traffic on a hot day, but its nowhere near as noticeable as an older car. I removed everything for the EVAP system - canister and all. I then took the vent line off the tank and extended it with a vacuum hose and ran it parallel with the filler neck. It exits next to the gas cap. I also got a vented locking gas cap just for good measure.
Old Jul 29, 2004 | 06:51 PM
SS1304's Avatar
Re: Deleting EVAP
since mine is deleted do I need to get a vented gas cap?
Old Jul 29, 2004 | 07:24 PM
PatriotTA's Avatar
Re: Deleting EVAP
It wouldn't hurt, since you need to relieve that pressure in the tank somehow. Its only a couple of bucks, and like I said, I haven't had any problems with it. I should mention that I programmed it out with Tunercat, too.
Old Jul 29, 2004 | 07:56 PM
Re: Deleting EVAP
I guess I am more into repairing stuff than removing it.
Old Jul 30, 2004 | 07:51 AM
SS1304's Avatar
Re: Deleting EVAP
haha
I like mine to be clean looking and stuff but hey if you dont need it take it out.
Old Jul 30, 2004 | 09:29 AM
madwolf's Avatar
Re: Deleting EVAP
Leroy,
If it was throwing a code, it doesn't necessarily mean it wasn't doing its main job. I would leave it on there. If you wanna know how gas fumes smell like, I invite you over to ride in my car for an hour or two. I don't even have it disconnected or disabled.
Old Jul 30, 2004 | 12:27 PM
aram's Avatar
Re: Deleting EVAP
I drilled a hole in my gas cap after I removed all the EVAP stuff. You need to relieve the pressure from the tank. I don't really smell any gas fumes when I drive.
Old Jul 30, 2004 | 02:13 PM
SS1304's Avatar
Re: Deleting EVAP
Originally Posted by madwolf
Leroy,
HAHA I will probally leave it on there then if that is what the majority thinks. I have a set of FRC to put on there to cover some of that stuff up and that will be going on next.
Old Jul 30, 2004 | 02:21 PM
Pasky's Avatar
Re: Deleting EVAP
Mines gone and I don't even have a cat and thier are no gas fumes I smell.
Old Jul 30, 2004 | 02:32 PM
southern78's Avatar
Re: Deleting EVAP
Does it hurt not to have a air tank to connect the evap to? I am running with a air tank but have the other connections hooked up.
Old Jan 11, 2005 | 12:54 PM
Mullet Z28's Avatar
Re: Deleting EVAP
What are you guys doing with the line that comes up through the driver side fender (bundles with fuel lines)? Are you cutting it off, or removing it entirely?
I'm assuming the reasons for removing that line is for looks and to avoid having gas fumes enter the cabin. Also, what size plug will I need to plug up the nipple on the throttle body?
MDZ28
11
Sep 24, 2015 09:15 AM
MDZ28
Sep 7, 2015 09:16 PM
350350
14
Aug 11, 2015 12:03 PM
tnmotown
Aug 10, 2015 11:52 PM
Alibi
Aug 1, 2015 07:50 PM
