Delco Lock II
Old Feb 26, 2003 | 03:17 PM
Greasepunk's Avatar
Delco Lock II
Any way to figure out the code? If not, will removing my radio from the car make it to where I cannot start the car or just render the stock system useless?
Old Feb 26, 2003 | 03:26 PM
CanadianZ's Avatar
Happend to me once. Went to the dealer. $30 Cdn later they made a 10 minute phone call and reprogrammed the radio to work. Any local dealer should be able to do it. Just try to find one that will do it cheap or free!!
CanadianZ
Old Feb 26, 2003 | 03:35 PM
A procedure for retrieving an unknown code has been posted here before. Did you try a search?
Old Feb 26, 2003 | 03:49 PM
Greasepunk's Avatar
yeah, but I always get wierd results with the search...it finds every word I type in, even if it isn't relevant to my search...
Old Feb 26, 2003 | 04:33 PM
Mtrhds94Z's Avatar
Try this:
Theftloc Bypass
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed
2. Write the numbers down.
3. Press the AM FM button, write down the next 3 numbers
4. Call 1-800-537-5140, when asked, enter 202107, press the “button” and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM FM button, SEC should be displayed, turn on radio
To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
Results not guaranteed... I found it in a search..
Aaront810
Aug 29, 2020 09:34 PM
magman
Apr 15, 2016 03:08 AM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
z28cam1993
Sep 9, 2015 04:08 AM
