Degreeing in new cam
Old Jun 11, 2004 | 10:54 AM
  #16
turbo_Z's Avatar
Originally posted by SILVERZZ28
You installed it correctly. Well the best you could without degreeing it.....
I just looked at the card again and actually I misread it. The LSA is 110 so with 4 degrees advance ground in the ICL is 106.. everything is cool. I was getting LSA and ICL mixed up.
Old Jun 11, 2004 | 09:03 PM
  #17
94foormula's Avatar
I get it but I'm still confused...
So all LT1 cams have advance ground in to them?
Old Jun 11, 2004 | 09:49 PM
  #18
rskrause's Avatar
Moderator
Not all. But most do.
Rich Krause
Old Jun 12, 2004 | 03:43 PM
  #19
Mindgame's Avatar
Haven't seen a cam maker yet that didn't give an intake CL for their cam card specs. If your lobe seperation is 110º and the specs are for a cam installed at 106º intake centerline, then the cam has 4º advance ground in.
Yes, the specs need to be checked. It's not just the cam you are checking, it is the whole assembly and the tolerance stacking that is involved in any mechanical assembly. It could be the cam... it could be the timing chain or gears, but you will never know unless you check. Just like checking piston to valve clearance. It's just one of those things you have to do and correct if necessary.
-Mindgame
Old Jun 15, 2004 | 09:57 PM
  #20
arnie's Avatar
I've posted on this subject in several threads in the past. If interested, IOW, haven't already made up your mind ahead of time, check the archives (tech and advanced) for my posts. Be forewarned, my posts were met with noteworthy resistance. Whatever words I had at my disposal, to attemp to convince the unconvinced, I've already posted. No point in being redundant.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
