decked heads........?
so how much can you deck lt1 heads before you need to also shave the intake down to compensate for the change in the angle between the intake and heads?
apparently i have a severe vaccum leak due to this. the leak is on the low side of the intake manifold gasket and apparently i need to have my intake machined down. does this sound right?
Re: decked heads........?
Originally Posted by rcmtby11
thanks for the response blackztpi. 35 views and 1 response...... good thing everyone didnt answer at once huh?
You got a response 3 minutes after you posted. Not good enough for you?
