decked heads........?
Old Jul 6, 2006 | 11:51 PM
rcmtby11's Avatar
so how much can you deck lt1 heads before you need to also shave the intake down to compensate for the change in the angle between the intake and heads?
apparently i have a severe vaccum leak due to this. the leak is on the low side of the intake manifold gasket and apparently i need to have my intake machined down. does this sound right?
Old Jul 6, 2006 | 11:54 PM
blackztpi's Avatar
Re: decked heads........?
that is right. usually anything over .010 will make a difference... .020 is when you need to start shaving the intake most of the time.
Old Jul 7, 2006 | 10:33 PM
rcmtby11's Avatar
thanks for the response blackztpi. 35 views and 1 response...... good thing everyone didnt answer at once huh?
Old Jul 8, 2006 | 05:30 AM
anaik's Avatar
Do you think everyone who views your post has the answer to your question?
Old Jul 9, 2006 | 06:59 PM
Black6spdZ's Avatar
my intake fit with decked heads and a zero decked block with fel pro head gaskets. I was just real careful starting the bolts.
scott
Old Jul 9, 2006 | 07:04 PM
MyZb383's Avatar
You got a response 3 minutes after you posted. Not good enough for you?
Old Jul 9, 2006 | 07:05 PM
Skull Leader's Avatar
Lightbulb Re: decked heads........?
I opened this post cuz I thought it was callin someone a ********.
alex5366
Jun 8, 2015 07:52 PM
Hobbyguy
May 26, 2015 02:15 PM
TitoPR221
May 26, 2015 12:20 AM
Spcquinn
Apr 10, 2015 04:02 PM
