deck hieght on 383
Old Feb 12, 2008 | 07:23 PM
mrl510's Avatar
deck hieght on 383
What is the usual deck hieght on a 383 lt1 that has a untouched deck?
Old Feb 12, 2008 | 08:32 PM
Cook Performance's Avatar
9.025
Old Feb 12, 2008 | 09:06 PM
greenmachinedriver's Avatar
are you asking for deck height or the distance the piston sits down in the cylinder. as stated before stock deck height is 9.025. the distance the piston is down in the cylinder will all depend upon the compression height of the pistons. it will be vastly different from build to build.
Old Feb 12, 2008 | 09:34 PM
mrl510's Avatar
Does it not change with a stroker?
Old Feb 12, 2008 | 09:45 PM
FASTFATBOY's Avatar
You need to mock it up,with the crank 1 rod and piston you will run in the engine... DO NOT guess. Mock up all 4 corners...they are all different.
Have the block square decked.
David
Old Feb 12, 2008 | 09:53 PM
mrl510's Avatar
The thing is that i have my pistons already, im worried that i didnt calculate right the first time what i wanted my compression ratio to be. I wanted 9.0:1 compression or a touch under but i think i got a good bit more than that. I have dish pistions w/ 20.4 cc dish. And 65cc combustion chamber heads. I hate to put the pistons in the motor to calculate if im gonna have to pull them out and resell them.
Old Feb 12, 2008 | 09:58 PM
mrl510's Avatar
oh and what i was looking for was the clearance between when the piston is at tdc and the deck on a stroker lt1
Old Feb 12, 2008 | 10:00 PM
rskrause's Avatar
Moderator
Read what David said.
Rich
Old Feb 12, 2008 | 10:05 PM
gota406's Avatar
Be sure....
David
...To read David's message. I have .012 difference in deck height from corner to corner on my block from the factory.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
