Deck Height,Quench, Static & Dynamic Compression?
Old Jun 15, 2008 | 08:11 PM
  #31
94zgreenmachine's Avatar
Originally Posted by ENRKyle20
look at that picture. the cylinder holes are not even close to being a perfect circle. I went and looked at the ones I have now and they look even worse.. geez, I tought they would be perfectly round!
but good price. I pad like $36 or somehting each for mine. maybe it was 26 but still!
What do you have now?
  #32
seawolf06's Avatar
Originally Posted by 94zgreenmachine
So that it doesn't stick.
I doubt any of the head gaskets are perfectly round. I haven't seen any for the LT1 that are.
Old Jun 15, 2008 | 08:14 PM
  #33
I meant why deal with it when you can get the Victor Reinz for that price ($15.95 each ). You can't get the MR. Gaskets for $32/pair any more. I see that is the price for each. I bought mine from Summit 3yrs ago.
Old Jul 10, 2008 | 12:10 PM
  #34
ENRKyle20's Avatar
Don't use the Mr.Gasket head gaskets. Use the Victor Reinz gasket from Napa. PN# 5898 . Same Gasket with out the packaging issues. Around $25 each . I had mr .Gaskets and I had packaging problems.
Damn. I called autozone and they recenty switched, they dont carry victor reinz anymore, he tried a cross refrence number and it came back with a stock thickness. Oh well. I just ordered 2 from CNC-Motorsports.
anyway. Is the quench somehting I need to measure?. or just knowing that my pistons are 10 in the hole and the thickness of my head gaskets enuff?. I was using soft solder to measure my quench ring on my snowmobile. it was not fun. lol
Old Jul 10, 2008 | 12:25 PM
  #35
seawolf06's Avatar
You just have to go by your deck height and gasket thickness.
Old Jul 10, 2008 | 01:11 PM
  #36
Try Napa, not autozone.
In the hole and gasket thickness is all you need.
Old Jul 10, 2008 | 01:56 PM
  #37
ENRKyle20's Avatar
thanks.. yea, sorry. typo. I did call napa. Thats the only place I called. The price was rigth at CNC-Motorsportes so I just odered from them. I also picked up a few other odds and ends I needed. I should be gettin my block back today or tommorow.. so I can finally start building!..
Old Jul 11, 2008 | 04:58 AM
  #38
rskrause's Avatar
Moderator
I didn't read the whole thread but I want to bring up something that goes contrary to some of the prevailing "wisdom" here. The idea that you have to have a very tight quench. It aint so. The fact that the thickness of a "typical" gasket is 0.039"-0.041" should tell you something - there really is no point try to get it closer. Unless it is a very unusual app, just zero deck it and use a standard gasket. Blower cars work fine with the piston pretty far down in the hole if deep dished pistons aren't in the budget.
Rich
Old Jul 11, 2008 | 08:08 AM
  #39
seawolf06's Avatar
Rich
So would you say there isn't much difference between .039" and .049"? (honest question )
Old Jul 11, 2008 | 08:17 AM
  #40
rskrause's Avatar
Moderator
Not much, if any from the qunech per se. Of course, with the thicker gasket you lose a bit of compression.
Rich
Old Jul 11, 2008 | 08:29 AM
  #41
seawolf06's Avatar
Rich
Yeah, a slight compression loss is a given. I'll stop worrying that I bought the wrong gaskets now. Thanks.
Old Jul 11, 2008 | 10:07 AM
  #42
ENRKyle20's Avatar
Well I just put them .010" in the hole and used a .026" gasket wich comes out to a fairy standard .036" quench. almost the same as with a zero deck and .039" gasket.
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Bxlt1
Sep 10, 2015 08:16 AM
Bxlt1
Jul 18, 2015 02:48 PM
