Dead Starter?
Old Jul 3, 2006 | 05:11 PM
EviLBoX's Avatar
Dead Starter?
Today I tried to start my car and it didn't even turn over, the accessories just turned on. I tried several times and didn't even hear the starter click. I can turn my headlights on and they don't appear dim or anything. After 5 or so minutes of trying to start the car and it making no noise, it finally started. Does this sound like my starter needs to be replaced?
Thanks.
Old Jul 3, 2006 | 07:40 PM
user 647483's Avatar
Re: Dead Starter?
Had a similar issue with my 92, happened mostly when it was cold.
Bad starter in my case.
Old Jul 3, 2006 | 08:51 PM
EviLBoX's Avatar
Re: Dead Starter?
Is there even a possibility it could be the battery?
Old Jul 3, 2006 | 09:40 PM
Re: Dead Starter?
Always possible I suppose; just because it quacks like my duck, doesn't mean it is my duck.
get it and the alt tested (free at most parts shops).
Old Jul 3, 2006 | 10:19 PM
EviLBoX's Avatar
Re: Dead Starter?
Okay, I think VATS may be the culprit. When I try to start my car the security light blinks, then I wiggle the key around a little and the security light eventually goes off and the car starts fine.
Old Jul 3, 2006 | 10:21 PM
Re: Dead Starter?
That's possible as well.
Re: Dead Starter?
I
Re: Dead Starter?
I used
Re: Dead Starter?
I used ot
Old Jul 3, 2006 | 10:24 PM
Re: Dead Starter?
That's possible as well; my manuals are are in my car (at the shop
getting heads/cam put in). Hopefully you will have a solution, if not i will look
up some troubleshooting steps as soon as I get them back.
Old Jul 4, 2006 | 12:14 PM
EviLBoX's Avatar
Re: Dead Starter?
I am able to start my car, however I have to wiggle the key around until the "Security" light stops blinking. I tried my spare set of keys and it has the same problem. Has anyone had this problem before? What needs to be replaced?
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
