Dead oil pressure gauge...NEED HELP!
Old Jun 23, 2004 | 03:57 PM
JJ's95B4C's Avatar
I've changed the sensor twice already, and the guage is dead. When I unplug it, it stays dead at zero. I had a mechanic put a mechanical gauge on there and he says there is oil pressure. The engine runs smooth as silk, so I know there is oil pressure. The engine is freshly rebuilt with a new high volume oil pump, and the pickup tube was tack welded, so I know for a fact that there is pressure. What next? What could this be?
Old Jun 23, 2004 | 04:14 PM
Either your gauge is broken or the wire lead for the gauge is pinched and grounded. With the connector off the sensor, your gauge should read max pressure with the key ON.
To help you isolate the problem, unplug C220 and turn your key ON (don't start). See what the gauge does. The gauge wire is in cavity "B", tan wire.
Old Jun 23, 2004 | 05:17 PM
JJ's95B4C's Avatar
Thanks shoebox. When we tested the cable, it showed that it was a negative cable. We sent a positive signal through there and the guage shot up. I just plugged it in and it works now, but there is obviously a short somewhere. How can I begin to look for this short?
HectorM52
Jul 30, 2017 11:46 AM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
