Daul Valve Springs=Wich Pushrods?
Old Apr 11, 2007 | 10:48 PM
turnin20s's Avatar
My ported heads that I bought have purple and redish orange springs in them. Will I be alright with some comp heat treated 7808s? Or should I step up to some hardened ones? I also have 1.6 pro mags on 7/16 arp studs and guide plates.
I was going to order the 7808s later next week, but if I need a stronger set please let me know. Sorry that I can't be more help, but I'd rather be safe than sorry.
Or (I'm Thinking out loud) should I have the spring pressure tested when I take them in to get looked over and then make my decision on what pushrods? The only thing that I don't want is to spend $100+ on a set of pushrods, but I will if its necessary.
Old Apr 11, 2007 | 11:37 PM
MachinistOne's Avatar
You don't need the $100 set of PR's. The cheaper hardened ones will be just fine.
Old Apr 12, 2007 | 12:02 AM
turnin20s's Avatar
So the 7808s will work? I was told to get those, but I thought I'd double check first.
Old Apr 12, 2007 | 12:09 AM
95LT1conv's Avatar
wh not spend the little extra for the good ones for piece of mind? you can usually find a set of used chromolly 1 piece in the for sale section for around $75
http://web.camaross.com/forums/showt...light=pushrods
Old Apr 12, 2007 | 01:06 AM
speed_demon24's Avatar
Just get the trickflow chromoly pushrods, they are the same exact pushrods as the comp hi-techs made by the same place, but $60 cheaper.
Old Apr 12, 2007 | 08:16 AM
seawolf06's Avatar
Assuming you've measured to know exactly what length pushrod you need, I'd say definitely get nothing less than a chromemoly pushrod. There are plenty of brands, but most are pretty much the same exact thing.
I have a setup very similar to yours and I didn't even bother with studded mains, but I sure as hell spent extra cash on good pushrods.
Wouldn't be a bad idea to get the springs tested if you don't know what they are. A good shop can measure your install height and the spring properties and tell you how you should shim them for optimum performance.
Old Apr 12, 2007 | 06:44 PM
turnin20s's Avatar
I know that they are setup right, but I was just going to check the pressure to see what pushrods to get. Also the reason for the main studs is I have heard that the bolts don't hold torque as well as the studs and that will cause you to spin bearings??? I don't know for sure, but for the extra few dollars it cost me I think they will be worth it.
You have a part # for the 7.195s? My heads have been milled, thats why I need the .195s instead of the .2s
Thanks guys
Old Apr 12, 2007 | 08:08 PM
.005" makes no difference.
Old Apr 12, 2007 | 08:36 PM
turnin20s's Avatar
Thats kind of what I thought, but I was just going by what I was told.
Old Apr 12, 2007 | 10:24 PM
seawolf06's Avatar
With milled heads and a zero decked block, I had to go to 7.1", but it depends.
Most of the aftermarket LT1 pushrods are 7.195".
Old Apr 12, 2007 | 11:42 PM
turnin20s's Avatar
Yeah, but my block is stock. I'll get a check tool to be sure. But I'll be getting the trick flows for $86 from summit unless someone knows where to get them cheaper
Old Apr 13, 2007 | 01:11 PM
seawolf06's Avatar
Those are the ones I was going to go with from Summit.
69z-28
Jan 29, 2016 10:46 PM
racecarz28
Mar 30, 2015 09:55 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
Red_94Formula
Jan 22, 2015 12:17 AM
