"Darn" head stud is leaking coolant. I'm livid.
Old Nov 21, 2004 | 05:47 PM
  #16
93turbo5oh's Avatar
Re: "Darn" head stud is leaking coolant. I'm livid.
what thread sealant did you use initially Dave?
Old Nov 21, 2004 | 06:10 PM
  #17
Dave88LX's Avatar
I don't know what brand it was...I didn't assemble it.
Old Nov 21, 2004 | 06:15 PM
  #18
Dave88LX's Avatar
Things are not good:
I count 4 leaking studs so far on the drivers side under the valve cover (not including the 2 or 3 external studs). The passenger side looks "OK" under the valve cover, but the drivers side, ugh.
Also, on that side there are 3 roller tips on my rockers that look like they started to wear out prematurely or something? I don't think I should have bronze showing already...and coincidentally, I don't know how but it was the 2nd from the front, and the rear 2 if I remember right that are like this.
Old Nov 21, 2004 | 07:05 PM
  #19
Dave88LX's Avatar
OK I lied, I have 5 rocker tips that have worn, not 3.
http://members.***.net/dave88lx/383/...tips-worn5.jpg
Old Nov 21, 2004 | 07:09 PM
  #20
Dave89IROC's Avatar
I can honestly say that I have never seen that before
  #21
93turbo5oh's Avatar
is that dexcool?
Old Nov 21, 2004 | 07:48 PM
  #22
Dave88LX's Avatar
Dexcool yeah.
On top of that as I was looking under the drivers side valve cover, I don't even have an oil coating or residue on the head there, it's like dry, way way dry. I ran my finger along the front oil drain channel and the whole area and no oil. I'm thinking for some reason, am I not getting oil up to that side of the engine?
Old Nov 21, 2004 | 08:00 PM
  #23
93turbo5oh's Avatar
dont run dexcool.
Old Nov 21, 2004 | 08:11 PM
  #24
Dave88LX's Avatar
Dexcool is what's supposed to be in there.
Why not, and what's the basis of your opinion?
Old Nov 21, 2004 | 08:15 PM
  #25
97 RedSS's Avatar
Dexcool is fine...Who did assemble this engine?
I would do like the others stated and do each stud individually and make sure it seals correctly...
Not sure what cause the rocker issue but I can speculate...1)Maybe the coolant in the valve covers caused them to turn that color 2)Rockers are set too loose and it banging on the valve...
Oil does take a few mins to reach top of engine since its the last component to recieve oil...I always pour oil all over the rockers before starting up to ensure good lubrication on a new motor...
Cody
Old Nov 21, 2004 | 08:19 PM
  #26
93turbo5oh's Avatar
a buddy of mine that is rather well known up here for building badass forced induction setups told me the dexcool breaks down the head gaskets. something about the chemicals in it. several older dealer mechanics ive talked to have said the same thing.
Old Nov 21, 2004 | 08:24 PM
  #27
97 RedSS's Avatar
Then why would if come in cars straight from the factory if it did that???
Old Nov 21, 2004 | 08:57 PM
  #28
Dave88LX's Avatar
Well, it was running for about 5-7 minutes with the coolant in it, and I've got oil in the top of the passenger side head, but the drivers side head is literally dry, except for the coolant in it. wned: That should have been plenty of time to get oil up there.
Old Nov 21, 2004 | 09:10 PM
  #29
chevyguy3's Avatar
just get a bottle of "Alumaseal" from autozone (silver bottle) and put it in the radiator. will fix your leaking studs within minutes and last a real long time, if not permanently. its very common for head studs to leak, and most guys just do that to cure it with no problems, including myself. mine were leaking very badly and havent seeped one bit since putting in the alumaseal.
as for oil not getting to the valvetrain... that wouldnt be related to your leaking stud problem at all, but its definitly a big problem
Old Nov 21, 2004 | 09:13 PM
  #30
Dave88LX's Avatar
Thanks for the info man. I'm not even going to worry about the head studs yet until I figure out why I'm not getting oil Sounds like a teardown may be in order...I can't think of anything I can check with the engine sitting in the car.
Does that alumaseal and other like products cause issues when you go to remove the studs for whatever reason?
