darn it
Old Oct 5, 2003 | 06:34 PM
Quick96Z's Avatar
darn it
I did my opti swap without even thinking of bumping my motor so that #1 or #6 were at TDC. Here's my question...Will my timing be off? I made sure i put my new opti back in the exact same place as the old one. I triple checked to make sure i put the same slot on the opti with the stud on the cam. In my mind, if i put the new opti back in place of where the old one left off, my timing should be ok...or maybe i am missing something.
I am waiting for my tranny to get done being rebuilt, so i cant fire her up quite yet. I really hope i dont have to tear it apart again.
thanks
trav
Old Oct 5, 2003 | 06:38 PM
RamAir95TA's Avatar
Opti orientation doesn't matter, as long as the cam and crankshaft are in the same relative location.
Just bolt it back on; you will be fine!
Old Oct 5, 2003 | 06:44 PM
Quick96Z's Avatar
that's what i needed to hear, i can now sleep good tonight!
Old Oct 5, 2003 | 07:26 PM
Not sure exactly what you meant, but I have to disagree with what you stated. The opti must be oriented properly to the cam for it to be timed correctly.
OTOH Quick96Z, it sounds like you put it on correctly as long as you put the special slot of the opti drive over the dowel pin. It does not matter what position the dowel pin is in, as long as you do it that way.
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
cmsmith
Apr 11, 2015 09:37 PM
Desolate_Flux
Classic Engine Tech
Jul 21, 2003 08:42 AM
Redbird
Nov 23, 2002 03:33 PM
BAD97Z28CONV
Aug 10, 2002 11:09 PM
