Dark Brown water in coolant system ?
Old Apr 8, 2004 | 01:17 PM
Spllouder's Avatar
ok i have had a ongoing promblem with cooling promblems and i have already changed my WP and temp sensor and flushed sysytem with hose and use some raditor flush solution . and still getting Dark brown and light brown sewer looking water from the raditor ,It also smells real bad. what is causing ths? has this happened to ne one else ? it seams the bad drity dark brown water is comming from the heater hoses ? is it the heater core ?
Old Apr 8, 2004 | 01:26 PM
TraceZ's Avatar
Re: Dark Brown water in coolant system ?
yes. Our heater cores are known for really nasty brown coolant. I'd suggest flushing the heater core seperate from the rest of the system very well.
Old Apr 8, 2004 | 06:28 PM
Spllouder's Avatar
whats the best way to do this ? will this fix my problem is the hater core gone bad ?
Old Apr 8, 2004 | 06:39 PM
TraceZ's Avatar
I'd recommend flushing it very well.. I wouldnt change it unless it was leaking, it is a PITA. just keep pushing water through it until it comes out clear.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Biggiebound
Apr 21, 2015 11:28 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Sandersen511
Jan 13, 2015 03:49 PM
pologreen97z
Dec 2, 2014 10:42 AM
