dang!!!
Old May 27, 2006 | 02:11 PM
crAzy95z28's Avatar
dang!!!
used my old boots from my old wires for the MSD wires. Wll got the driver side all hooked up. Tried started the car. No start. Just turns over and over and over. Looked at the coil wire. Looks fine to me, but no start.
Would it matter if i had 8mm on one side and 8.5mm on the other?
Old May 27, 2006 | 02:24 PM
user 647483's Avatar
Re: dang!!!
I wouldn't think that that would prevent the car from starting.
At the very worst, it might make it run rough.
The fact that it keeps turning and not starting tells me that the wires are either on the wrong plugs or the coil is not connected or firing.
I'd double-check those first. Check for blown fuses as well.
Do you hear any ticking? And is the fuel pump starting when you put the key in?
Old May 27, 2006 | 02:38 PM
crAzy95z28's Avatar
Re: dang!!!
it was the iginition coil wire. It wasnt touching the nipple on the opti.
Old May 27, 2006 | 02:39 PM
crAzy95z28's Avatar
Re: dang!!!
Id rahter change spark plugs than do these damn wires.... lol
Old May 27, 2006 | 02:40 PM
Re: dang!!!
it was the iginition coil wire. It was touching the nipple on the opti.
I love easy and inexpensive fixes
Now go blow a tank of gas enjoying the car and you will feel much better
Old May 27, 2006 | 02:41 PM
crAzy95z28's Avatar
Re: dang!!!
still have passenger side to do
Re: dang!!!
After I did my headers, I installed OTVC wires.
Hopefully this will be the last time I have to do plugs/wires for a long long time.
Noct
Jul 14, 2015 01:18 AM
krazzycowgirl
Pacific
25
Mar 7, 2004 01:28 AM
Fastbird93
Aug 17, 2003 04:06 PM
Hal Fisher
Mar 18, 2003 03:36 PM
