Dampener
Old Jun 1, 2008 | 08:42 AM
ShownomercyZ28's Avatar
Dampener
Is there a way to remove the dampener without an impact gun? I was thinking someone else on another bolt so I don't turn the motor over. But I don't know. What do you guys suggest? Heads/cam, so yes it needs to come off. 95 Auto.
Old Jun 1, 2008 | 08:59 AM
cnorton's Avatar
If possible with your set-up, access the starter ring on the flexplate. It is possible to prevent the engine from turning by using a flywheel turner or inserting a screwdriver in the teeth on the starter ring. Clearly, this is not a job for one person working alone but it can prevent the engine from turning while you are exerting rotational pressure at the front of the crank.
Old Jun 1, 2008 | 12:46 PM
Procharged94Lt1's Avatar
I have also heard of people inserting 12" of rope in a one of the cylinders and rotating the motor until the rope compresses and holds the motor. Not sure about it, but I doubt the relatively small torque of taking the bolt off compares to amount of stress it goes thru in a firing pattern.
Old Jun 1, 2008 | 04:46 PM
I am just going to borrow an impact gun tmmr. Thanks for the ideas though guys!
Old Jun 1, 2008 | 09:58 PM
seawolf06's Avatar
Did you try putting a wrench on it and hitting it with a rubber mallet or hammer?
CheshireCat
May 31, 2006 01:07 PM
NVetro
Oct 14, 2005 06:05 PM
Tom Piper
Aug 5, 2005 06:59 PM
Damon
Advanced Tech
Apr 22, 2004 06:46 AM
Ted 99 TA WS6 Conv
10
Jul 30, 2003 06:41 AM
