Engine Rebuild with a H/F oil pump
Old Jun 1, 2008 | 03:54 PM
Ekof96Z28's Avatar
Hey guys. I was looking at some rebuild kits from Summit for my 95 LT1. They include pretty much everything at rather attractive prices.
It also includes SLP-224-43469V
Thats a p/n for a high flow oil pump.
I had heard that high flow oil pumps in LT1 engines can cause more problems than they help.
What is the current consensus on this? Do9es anyone know of a better rebuild kit than the one offered by summit?
Can anyone recommend me a better route to go for the 600 dollars I would spend on the rebuild kit.
It includes all bearings, all gaskets, forged pistons, oil pump, among other little things.
Any recommendations?
Old Jun 1, 2008 | 10:02 PM
seawolf06's Avatar
You should not use any "high flow" oil pump with the stock pan. Moroso makes a good pan as do others if that is the route you want to take.
I'm not a fan of any rebuild "kits" as they usually contain inferior parts and are stock specs. If you're going to go through the trouble and money required for a rebuild, you should improve upon what came from the factory, IMO.
Otherwise you should save yourself the trouble and buy a crate motor.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Captain Kirk
Jul 26, 2002 06:39 PM
