damn valve spring compressor
Old Aug 3, 2005 | 10:26 PM
snakethis69's Avatar
i am having the time of my life with this compressor contraption. i eventually get it but its a pain? anyone to comment /help?
Old Aug 3, 2005 | 10:31 PM
raroz28's Avatar
Re: damn valve spring compressor
You want this tool. I did valve springs a few weeks ago, and this tool made it a piece of cake. Very easy to use. Heads were on the car as well.
Old Aug 4, 2005 | 01:20 AM
Heatmaker's Avatar
Advanced Member
Took me 2 days with the 14 dollar Autozone Compressor.... 1 day getting them off... one day getting them on.... next time I think I'll buy hte 100.00 one and get it done out right... what a headache..
There's only one word of advice for Valve spring compressors "patience"
Old Aug 4, 2005 | 02:14 AM
carolinacasper's Avatar
I had the same problem with the crummy Autozone compressor. I got mad at it and broke it so I had to buy another one. It took me two days as to swap my springs out.
Old Aug 4, 2005 | 02:29 AM
MachinistOne's Avatar
If you pay the good money to start with and get the quality one it will only take 5 min each max to remove and swap springs and seals.
Old Aug 4, 2005 | 07:19 AM
89385formula's Avatar
The one I have seems to work very well, i used it to take of my Comp 977's a weeek or so back...took me like an hour or 2. I have used a couple before that were pieces of junk and were a nightmare to use. Tools are one place you really need good, quality pieces...they can really make a night and day difference when doing work on your car.
Old Aug 4, 2005 | 07:22 AM
Feenix's Avatar
what one are you guys using, and where do you get it?? P/N maybe?
Old Aug 4, 2005 | 08:02 AM
NBred94's Avatar
I started with a spring compressor from KD tools that worked well for a while before the threads decided to eat themselves and the thing literally fell apart. I finished the job using one with a similar design (screw type) that i got at a Sears Hardware store. It was a simpler design and was just built much better.
Unless you have small fingers and very steady hands, I don't see how replacing valve springs isn't going to be a pain in the butt. It probably took me 12 hours to do the springs and rockers start to finish, would have been faster with help though.
Old Aug 4, 2005 | 09:45 AM
The one I currently have is from Advance auto parts, its really not that nice...but seems to work pretty good. It has a wheel on the top that tightens it down, then when the spring has compressed I hit the top of the compressor with my hand, and then hold it down. Its always a pain to get the locks out, so I use a very small screwdriver with a magnet on the end to pull the locks. I know this tool isn't of the highest quality so I will be on the lookout for one that resembles it, but stronger looking piece...although this one does have a lifetime warranty.
Old Aug 4, 2005 | 11:03 AM
well i was suckered into the one from auto one, i would think that would vary the arms lengths so it tightens down evenly
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
