D Block lt1
Old Mar 22, 2013 | 10:11 PM
mayhem like me's Avatar
Exclamation D Block lt1
i just bought a d block lt1 from a good friend because my orignal block spun a bareing and i was wondering what parts should i change in my new block to insure no problems any time soon
Old Mar 22, 2013 | 10:15 PM
RamAir95TA's Avatar
Re: D Block lt1
D block?
Old Mar 22, 2013 | 10:20 PM
Re: D Block lt1
yes a dblock those come out of 94-96 cadillac fleetwood
Old Mar 23, 2013 | 08:42 AM
Kevin Blown 95 TA's Avatar
Re: D Block lt1
You know more than we do.
Old Mar 23, 2013 | 10:26 AM
Re: D Block lt1
What is the difference between that block and any other LT1 2 bolt block? I've never heard the reference to "D block". IMO, you treat it as any other rebuild. Use quality parts and pay attention to tolerances.
Old Mar 23, 2013 | 01:47 PM
KW Baraka's Avatar
Re: D Block lt1
Originally Posted by shoebox
.......I've never heard the reference to "D block".......
"D-block" is really a misnomer. The Caddy is a D-body.....slightly longer than the B-body.
This engine is exactly the same as the B-body LT1. This means it has a torque oriented cam and iron heads.
OP.....I'm assuming you have a F-body; so if you're not gonna rebuild.....then you could drop the engine in 'as-is' and it'll run fine (A bit more torque below 3K RPMs.....less power above 4K RPMs).....even with your stock tune.
BUT.....those heads are heavy as he11 and the weight will tax your front suspension.
If you want what you already got.....swap out the heads/cam from your current engine......and swap out all your accessories and you'll be fine .
KW
Old Mar 23, 2013 | 03:22 PM
Re: D Block lt1
Yeah, I knew the Caddy was a d-body. Just trying to figure out why the OP thought the engine was different.
Old Mar 24, 2013 | 10:07 PM
KW Baraka's Avatar
Re: D Block lt1
Oh.......OK
KW
D1SC383LT4
Jan 1, 2016 01:56 PM
willismoons
Feb 14, 2015 08:42 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
squinn
Aug 4, 2002 01:06 PM
