Cylinders 4 and 8 misfire?
Old May 1, 2009 | 08:39 PM
LSWHO's Avatar
I've got a multiple random misfire going on for a while. I finally got my scanner to read my cable.
Anyway, is there any significance to cylinders 4 and 8 having misfires? The other ones when I scanned were fine.
4 had the most, but 8 wasn't far behind.
Old May 2, 2009 | 05:55 AM
Guest47904's Avatar
Guest
Any history to the problem like did it happen out of the blue. After having done some work etc.....
Otherwise it's time to pull wires and plugs.
Old May 2, 2009 | 01:27 PM
LSWHO's Avatar
The plugs are new. The po300 isn't. It's been plaguing me forever. I'm just wanting to fix it right the first time, so I don't wast too much money.
The problem I believe has been there since I bought the car. Or at least since the first stall swap. I first noticed it a few weeks after my Tranny install, where it wouldn't want to lock up the converter at a 46mph cruise.
Old May 3, 2009 | 11:10 AM
Misfire counts similar on two cylinders may point to cross-firing on the wires, where they pass close to each other. There is also a possibility of carbon tracking on the distributor cap, since #4 immediately follows #8 in the firing order, and the metal contacts in the cap are next to each other.
Old May 3, 2009 | 11:57 AM
LSWHO's Avatar
New wires I assume is #1 then.
How would I fix this? Take apart the opti? Replace it?
Old May 4, 2009 | 05:29 AM
Guest47904's Avatar
Guest
Swap the wires first. Don't keep buying things.
Problem either moves or it doesn't. Get it?
Problem moves, wires is the problem. Problem doesn't move, go for plugs or injectors. Got it?
If that doesn't fix it, pull the cap off the opti and look at the inside of it and rotor.
Old May 5, 2009 | 12:16 AM
LSWHO's Avatar
Yeah, I'm an idiot. Can't believe I didn't think about the swap. I've done this before I swear.
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
