cylinder head torque
Old Mar 22, 2005 | 07:25 PM
J96Z's Avatar
Does anyone know what I need to torque these head bolts to? My chiltons book says to torque them to 22 ft lbs and then turn the long ones 80 degrees more and the shorter ones 67 degrees more. Seems kind of silly to me. What should I torque them to without having to figure out if I'm turning them too much. Stupid Chiltons.
Old Mar 22, 2005 | 07:27 PM
JONEZ_Z's Avatar
Re: cylinder head torque
Are they stock bolts? You should use new ones if can afford it. ARPs But anyways i would probably torque them to about 65#s
Old Mar 22, 2005 | 07:30 PM
J96Z's Avatar
I bought a set of ARP's. Thats whats going on the car.
enzo1267's Avatar
65 lb per foot as per instructions in the factory service manual
Old Mar 22, 2005 | 07:55 PM
Bawls's Avatar
If you're putting ARP head bolts in, then use ARP tq specs. I've got my instruction sheet infront of me.
[ A ]Torque valves are based on 75% of the fasteners yield strength. Use the manufactures torque sequence but do not use the engine manufactures torque specs. Torque the bolts to 65 ft lbs for ARP MOLY ASSEMBLY LUBRICANT (or ARP THREAD SEALER) or torque to 85 ft lbs with 30wt motor oil.
[ B ]Due to the heat expansion rate of ALUMINUM, it is recommended that the torque should be 60 ft lbs with ARP MOLY ASSEMBLY LUBRICANT (or ARP THREAD SEALER).
Old Mar 22, 2005 | 09:12 PM
Those are the torque to yield values and no, they are not stupid. The TTY method is meant to give more accurate clamping forces that are less skewed by friction.
Starting in 1996, the factory shop manual shows the TTY specs just as the Chiltons does.
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Jason Short
Jan 19, 2015 06:34 PM
Elcojoe
Nov 17, 2014 10:27 PM
