Cylinder head removal ????
I'm about to remove the heads on my 94 6 speed and was wondering what the proper procedure was. It doesn't look too fun being that half the motor is under the cowl. Is there anything I should look out for or any tips that might make things easier.
Thanks, Any help is greatly appreciated. |
LOTS of patience. Not too hard. Get the manfiolds off, thats a little frustratiing. www.shbox.com has a good write up for when you are ready to remove the intake manifold. Its under the cam install guide. Im stuck in my removal because of a rounded off head bolt
its verry easy unless you have long tubes in the way like i did but it still wasent bad you should buy a chiltons or hanes manuel they come in handy
It's a lot of fun, except for the coolant end of it. :D
Hey Rob, you think its nessecary to take the knock sensor out? I already took the block drain plug out, but there is more coolant coming out of the lower head bolts on the passanger side. I thought draining the one side would be good. |
ty
thanks for the link shoebox, that will come handy when i get ready to install my cam and new heads ;o
Originally posted by ibanez6rg It's a lot of fun, except for the coolant end of it. :D Hey Rob, you think its nessecary to take the knock sensor out? I already took the block drain plug out, but there is more coolant coming out of the lower head bolts on the passanger side. I thought draining the one side would be good. |
Thanks for the links and info guys. I'm going to deffinatly buy a Chiltons so I can have some under hood guidance.
Thanks again. |
