cylinder 3 missfire
Old May 19, 2006 | 07:44 PM
allblacksrt4's Avatar
cylinder 3 missfire
i was going to get my smog done today and out of nowhere my check engine light came. went to the smog guy hey scanned it for me as a cylinder 3 missfire. i just put in the delteq 4 months ago along with new plugs and wires. i'm going to check my #3 plug wire anything else i can look for? thanks
Old May 19, 2006 | 07:53 PM
Re: cylinder 3 missfire
one more thing. i tried just resetting the ecu. check engine light goes away for about 30 min but car is almost undriveable, once warm up check engine light goes on it runs fine. no hint of a miss at all
Old May 20, 2006 | 01:04 PM
What year is your car? Its almost impossible to get accurate answers without providing at least the basic info about the car. Add a "signature" with year, model, tranny, major mod's, etc.
Was the SES light flashing? That indicates its a misfire code. A steady light indicates some other code. That's why the year of your car is important, since there is only misfire detction in the 96/97 OBD-II LT1's.
Old May 20, 2006 | 03:17 PM
sorry i do have a sig but it didn't show up. it's a 97. i checked the plug it was alittle loose. tightend that cheked the plug wire w/ a multimeter and then came up fine. check engine light went away for alittle car got normal temp and missed and light came on again. all plugs wires and deltec are less then 6 months old.
Old May 20, 2006 | 08:32 PM
changed #3 plug wire ran good 20min later when driving same code p0303? but i do not feel a miss at all it runs real strong. is there more then one way to rest the ecu?
Old May 20, 2006 | 10:45 PM
respectirocz's Avatar
misfires happen because of one or more of 3 things
ignition, fuel delivery or compression
your ignition system does not seem to be the culprit but you cant rule it out just yet
i like to do a compression test just to be sure
maybe run some fuel injector cleaner to try and clear up a sticking injector
Old May 23, 2006 | 04:54 PM
tried pulling plug on injector car ran like crap. could a o2 sensor be the problem?
Old May 24, 2006 | 12:46 PM
bump for some help
Old May 24, 2006 | 01:11 PM
i am going to try and run fuel injector cleaner. any other way to test injector other then changing it
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
