Cutting rear springs!
Old Mar 27, 2003 | 09:42 PM
SunCoastTA's Avatar
I want to cut my rear springs to make it sit a little lower in the rear. I like the way the front sits but the back is too high. Are there any tips you guys can give me before I do it. Like how much to cut off. ect ect................
Old Mar 27, 2003 | 09:46 PM
Jcb890's Avatar
i personally wouldn't cut the springs at all...maybe purchase some coil overs from eibach or get some new shocks like the QA1 or something....hope this helps, im sure people who know more about suspension will chime in 4 ya.
jake
Old Mar 27, 2003 | 09:49 PM
95 Z/28 LT1's Avatar
Super Moderator
I wouldn't cut them. Try taking out the rubber spacer first and see how much you like it.
Old Mar 27, 2003 | 09:59 PM
SunCoastTA's Avatar
Thanx guys, If I remove the rubber spacers will it affect ride quality?
Old Mar 27, 2003 | 10:20 PM
Not as much as cutting the spring.
Old Mar 27, 2003 | 10:38 PM
Rx-7 SS's Avatar
I dont think there is any excuse for cutting springs when lowering springs can be had in the $250 range. Its just not worth it.
Old Mar 28, 2003 | 12:20 AM
1982z28with18s's Avatar
Just deflate your rear tires and you will set lower to the ground in the back.
Old Mar 28, 2003 | 12:33 AM
GhostZ's Avatar
I agree with RX-7 SS....why be ghetto and not only affect your ride quality but your safety when spring can be had for so little money.
If you can't afford new, check out the for sale section....you may run across a good deal there.
Old Mar 28, 2003 | 03:15 AM
chesee48's Avatar
I agree, if your going to lower the car, DO IT RIGHT! i mean please, u can get a set on the board for like 150. Why would u cut them?
ModdedNerd
Dec 25, 2014 05:51 PM
cmdeshon
Dec 12, 2014 10:51 PM
Dec 4, 2014 11:56 AM
wytblur
Mar 2, 2003 03:40 PM
