Custom Y-Pipe finished w/ pics
Well after looking at all my options to finish my exhaust, I had decided on a custom y-pipe and Magnaflow cat back. I'm pretty happy so far with my car since the new motor went in, and that continues with the work Stage 1 Automotive in Pompton Plains NJ did for me. I actually created a cardomain page, here's the link:
http://www.cardomain.com/memberpage/737724
I'll add more pics when I get a chance to scan them.
Re: Custom Y-Pipe finished w/ pics
Originally Posted by mitchntx
So, what are your thoughts on the cat being so close to the clutch slave?
Hmmm didn't think of it being an issue, have you heard anything about that? The cat does have a heat shield welded onto if.
The setup is modeled after an LS1 aftermarket pip, less bends and better airflow that the random tech piece. I would'ver had to modify that to fit anyways so went this route anyways.
I put more pics on my cardpmain page if ya wanna check em out...
SD
Originally Posted by kingman109
so how much that run u - im in need of one for my shorty's and catback-
def willing to drive to that shop and have done
The cats were $110+shipping on e-bay
The pipe was around 300, I have to dig out the receipt for the exact amount, he's kinda far for you too man, Pompton plains, NJ has to be far...
Originally Posted by bozobuttz
Are the cats altered from their stock locations at all?
Originally Posted by Turbo6
That looks like the stock flange on the drivers side. Isn't the pipe there 2.25" whereas much of the aftermarket stuff including the Random Tech 2.5"?
Good eye Turbo, aye it is, however the y-pipe is 2 1/2" pipe. The BBK header is a 2 1/4 collector to bolt up to the stock pipe. I had done some research and felt a stock-head car w/ a hotcam would breathe fine w/ 1 5/8 primaries, and it seems to be just right, slight backpressure at the muffler, not up in the cats or primairies. Also this pipe is stainless steel, the Random tech pipe is aluminized(sp?).
Summitt sells a stainless dual cat pipe for $550, both that and the Random Tech pipe I would have had to have modified anyways to fit the BBK headers so I went full custom. No complaints whatsoever...
live in CT -
going home in 3 weeks
Apr 3, 2015 10:54 AM
ddr698
Jan 31, 2015 10:58 AM
