Custom true duals, need opinion of setup
Old Nov 19, 2005 | 10:36 AM
  #16
97WS6SCharged's Avatar
Re: Custom true duals, need opinion of setup
Originally Posted by MEAN LT1
What I plan On having built. But then again I'll be sporting a solid roller 383. Yea, I think I'll need 3". hehe.
Why would you need 3" pipe for a 350 horse motor?
3" can be done, but 2.5 will fit a little better.
Old Nov 19, 2005 | 10:59 AM
  #17
JoeliusZ28's Avatar
ANd since I dont have a CME, just atke away those last 90 degree bends at the end. But you get the jist of it.
wow thats a beautiful setup, what kind of mufflers are those? is that 2.5" piping? looks like theres room for dual cutouts before the axle too
Old Nov 19, 2005 | 12:19 PM
  #18
MEAN LT1's Avatar
There Magnaflows mufflers
Old Nov 19, 2005 | 02:41 PM
  #19
Loadre's Avatar
2 1/2 duals are more than adequate. Whoever was telling you to go 3" duals is a tard and should be shot.
Old Nov 19, 2005 | 04:27 PM
  #20
fast96lt4's Avatar
I went 3in true duals dumped at axle Didn't loose any power and clearance was still great. The reason I went 3in was for a louder exhaust note. My buddy has same set-up But with 2 1/2in, and mine is noticeably louder.
Old Nov 19, 2005 | 05:12 PM
  #21
Mindgame's Avatar
Build it once.
If your goal is to eventually make 450+ fwhp then build a 3" system. If you plan to stay under that then I'd stick with 2.5".
The more hp you make, the more you are going to lose if the exhaust is smaller.
-Mindgame
Old Nov 19, 2005 | 06:22 PM
  #22
CANTONRACER's Avatar
I ran high 11's on a stock exhaust (no cats though) with a flowmaster muffler.
Old Nov 19, 2005 | 10:00 PM
  #23
Harvey's Avatar
Question Re: Custom true duals, need opinion of setup
Would there be any loss in going with a 3" exhaust instead 2.5" exhaust on a bolt-on car due to less back pressure? That's why you would lose torque down low, right?
I'm about to order a set of stepped Kook's and TSP Rumbler 3" exhaust. Will be building a 383/LE3 down the road and only want to buy this exhaust stuff once. Still interested in what y'all think will happen to my car right now though.
Wayne
Old Nov 19, 2005 | 11:52 PM
  #24
94sinister's Avatar
Wayne
I'm not an engineer or physicist, but I would assume - if anything - you would see gains going with 3" over 2.5". IMO the only reason people should be debating to go with 3" or 2.5" true dual setup should be ground clearance or possible sound differences.
BTW I have stepped Kook's LT's with their 3" ORY going into a TSP Rumbler. Sounds great and has a really deep and bass(y) sound in the lower RPM's (literally shakes the change in my cupholder). Upper RPM's start to scream and somewhat sounds like GMMG. I've gotten numerous compliments on it.
I'll have to get a better vid BTW It doesn't pop anymore either
http://video.ls1tech.com/player.aspx...E-92E223516EC2
Old Nov 20, 2005 | 12:16 AM
  #25
Mindgame's Avatar
I agree... the only loss you'll see is 1/2" of ground clearance.
On another note, I've never understood the arguement... "well, if I made XXX power with this suboptimal part it must not be that bad right.
Let me rephrase that to read like it should.... "I'm happy using parts that I know are costing me some hp just to say that I can make decent power with them."
Much better...
-Mindgame
Old Nov 20, 2005 | 11:54 AM
  #26
SStrokerAce's Avatar
Agreed...
Just because a setup has made XX amount of power with a part doesn't mean that it's the right part for the job. I can't stand conclusions that come from a situation where the scientific method was not applied, or the other part in question was never even used.
Bret
Old Nov 20, 2005 | 01:33 PM
  #27
MEAN LT1's Avatar
On another note, I've never understood the arguement... "well, if I made XXX power with this suboptimal part it must be not be that bad right.
Much better...
-Mindgame
That took me reding that statement like 10 times before I got what you were saying. I understand now.
Old Nov 20, 2005 | 04:37 PM
  #28
slverbullet's Avatar
evil erik, i apologize if my above replies were too vague. i did check out your website and saw the estimation of your current hp as 350 (as to flywheel or at the wheels, i am uncertain. assuming the power is at the wheels, i added a liberal 20% drivetrain loss and concluded that you would be at ~420 fwhp). i assumed the original question was referring to your current vehicle setup and that you inquired as to what would be a good dual exhaust setup for you now. i believe that dual 2 1/2" exhaust tubing would be adequate for your current needs. i have no scientific data that would suggest otherwise, although the original post title does state that you are looking for opinions. i do agree that 3" piping is more efficient to a point as you go up in power. at which exact point, i can offer you no advice. perhaps mindgame's notation of 450fwhp+ would be a good starting point as for when you might want to start looking into the 3" dual setup. his knowledge of cars and physics far exceed that of mine and i would seriously consider his opinion on the matter.
Old Nov 20, 2005 | 08:09 PM
  #29
firebirdStud's Avatar
holly vagina that looks hot! Damn I think I might have to try that! good job with the car "mean lt1"!
Old Nov 20, 2005 | 09:24 PM
  #30
Harvey's Avatar
Thumbs up Re: Custom true duals, need opinion of setup
94sinister, do you mean complaints from close neighbors? If so, I really don't care too much. They'll have to get use to it. All I got to say is that it'll be their wake up call at 0430 in the morning. I don't know if it will be any louder or what, but I am going with the X-pipe Rumbler setup from TSP. It is really for an LS1, but they said all I would need to do is get the drivers side pipe bent about 3/4" one way to make it fit.
Wayne
