Custom true duals, need opinion of setup
Old Nov 15, 2005 | 09:59 PM
Evil Eric's Avatar
Im going to be swapping my hooker mid's out for a pair of pacesetter long tubes, I was wanting to get some of our all's opinions on weather or not there is a signifigant differance in sound between 3" and 2 1/2" piping ? im going to go with an x-pipe setup and probably sweet thunder mufflers. I was considering going with 2 1/2 tubing because it would slightly offer more ground clearance.
Old Nov 15, 2005 | 10:02 PM
slverbullet's Avatar
Re: Custom true duals, need opinion of setup
2 1/2 should be more than adequate for your setup. i use 2 1/2 and it works great for me.
69gto96z's Avatar
IMO, if you are running true duals there is no reason for 3" piping on a LT1, assuming your is N/A and under 400 HP. I had dual 2 1/2" on my 350 HP GTO with a big block, and never had any performance issues. You will get better ground clearence, and it will cost less to.
Old Nov 15, 2005 | 10:04 PM
69gto96z's Avatar
BTW, car looks good.
Evil Eric's Avatar
Reallllly now...I was talking about this on a local message board and most people were bashing me telling me that 2 1/2 is far to small, that i should keep the y-pipe and go with a 4" pipe, or use 3" for the x-pipe. I had a feeling it was just personal opinion.
Old Nov 15, 2005 | 10:42 PM
mebanditws6's Avatar
I went with a 3" setup and didn't lose a wit of low end. If anything, I gained torque across the board. Credit that to the X crossover. Because Lane's doesn't have a jig for LT1 cars, the best/easiest route would be to order the Summit or Jeg's universal X pipe kit and take it to a muffler shop to have them tweak it and weld it up. If you have slip fit collectors, band clamps work great.
Jason
Old Nov 15, 2005 | 10:58 PM
Evil Eric's Avatar
As far as sound goes do you think reducing the size of the muffler from 3" to 2.5" make a huge difference in the sound of the setup?
Old Nov 15, 2005 | 11:03 PM
69gto96z's Avatar
It will be louder with bigger pipes.
Old Nov 18, 2005 | 10:09 PM
revtime's Avatar
I run Hooker LTs and purple horny header mufflers (3 inch) and I don,t feel any loss down low.
I have an auto with a stall and gears though.
Old Nov 19, 2005 | 04:30 AM
CANTONRACER's Avatar
SOTP = worse dyno in history.
A dual 3" exhaust is a lot bigger than even a single 4" exhaust....do you need a 4" exhaust...like the guys running 9's?
Look how many people are cooking on single 3" systems....
Old Nov 19, 2005 | 05:33 AM
if you're staying single pipe exhaust, then 3" is good. but i dont think there is any benefit to going 3" dual over 2 1/2". and all you people saying you dont feel any loss with low end w/ 3" dual, did the dyno show the same? let me see a direct comparison to the 2 1/2" vs. 3". i doubt you'll show any gain going from 2 1/2" to 3" dual with your setups.
Old Nov 19, 2005 | 06:35 AM
amean94ta's Avatar
mine is going to be pacesetter long tubes, cutouts, 3 in x-pipe, dynomax bullet's with turn downs my buddy has it and it sounds like heaven
Old Nov 19, 2005 | 08:50 AM
MEAN LT1's Avatar
What I plan On having built. But then again I'll be sporting a solid roller 383. Yea, I think I'll need 3". hehe.
Old Nov 19, 2005 | 08:52 AM
MEAN LT1's Avatar
Old Nov 19, 2005 | 08:53 AM
MEAN LT1's Avatar
ANd since I dont have a CME, just atke away those last 90 degree bends at the end. But you get the jist of it.
