Custom ground cams??
Old Dec 19, 2003 | 09:18 AM
OutKast's Avatar
I'm in the market for a cam and have heard many say that you can't beat the performance of a custom grind. If I wanted to go this route...what kind of info do I need to provide for them to determine the best grind for my combo?
Old Dec 19, 2003 | 09:57 AM
importeater's Avatar
Never done it before but I would imagine, any and every mod you have done, injector size, fuel system limitations, what heads with valve sizes, spring heights, flow numbers, ext... What trans you have, gear ratio, to spray or not to spray.. Not sure if they will need to know trans and gear ratio but it would make sense they would want to know so they know how quickly your RMP's are increasing. I would think that should cover it. Well most importantly you goals!
Craig
Old Dec 19, 2003 | 11:24 AM
94formulabz's Avatar
You need to tell them all your mods and engine specs. Ported heads with flow numbers, port volume, and most importantly someone who knows what they are doing to spec the 'custom' aspect of the cam. Bret Bauer and Joe Overton come to mind, not your neighbors friends cousins buddies mechanic.
-brent
Old Dec 19, 2003 | 11:37 AM
nitropatch's Avatar
i would recommend combination motorsports, thats where i got my custom cam from, all you do is tell them what y ou got they have most of the stuff on a computer so they would be a good place to go.
Patch
Old Dec 19, 2003 | 05:05 PM
BUBBA's Avatar
Cams, I assume, are offered based on experienced results, but of course, they may provide different results based on the platform.
Ordering a "custom" ground cam begs the question of what, other than bench work, is the expected results based on...PLUS the added conditions of the varying platforms.
I.e., why would anyone order a "custom" cam unless they were building a "custom" engine? JMHO
A custom cam probably will cost more and may not provide the results you had hoped for and may be tough to unload if you aren't happy.
Old Dec 19, 2003 | 10:23 PM
OutKast's Avatar
Well, I've seen that going custom is only $30-40 more. From what I've read here and on other forums it seems others are getting good munbers with the custom grinds. I assume they will want flow numbers but not sure what else....
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
CARiD
Jan 14, 2015 04:00 AM
Collector Car
Jan 5, 2015 10:58 AM
