csr help please
i bought a csr ewp from summit, i almost got everything to go, but i noticed the pump won't fit into the water pump housing cause the pump has small notches on it,
my question is what did any of you guys do? do i grind down the notches on the pump or do i grind notches into the pump housing?
You grind the notch on the housing.
MysticTeal 95 V6
Apr 30, 2004 11:40 PM
