Csr Ewp
Old Jun 22, 2006 | 01:39 PM
fastchevy's Avatar
Csr Ewp
I'm putting mine on today after work. The little O ring on the CSR is pretty wimpy, is it enough to seal it properly?
TIA
Old Jun 22, 2006 | 01:45 PM
blkchevyz's Avatar
Re: Csr Ewp
i used some rtv sealent along with the seal. havent had a leak and its been on the car for 3 or 4 years now.
Old Jun 22, 2006 | 10:07 PM
fastchevy's Avatar
Re: Csr Ewp
Cool, thanks...sounds good.
Old Jun 23, 2006 | 07:15 AM
CrystalSS's Avatar
Re: Csr Ewp
I did not use any sealer and no leaks at all.......... FYI after grinding the original housing for the nibs on the pump check the impeller to housing clearance.......mine slightly hit. Probably mentioned here before.
Old Jun 23, 2006 | 08:31 AM
fastchevy's Avatar
Re: Csr Ewp
Yeah I've read that, but a good reminder. I'll check it out.
Jlo
Feb 3, 2015 09:41 PM
Wicked 97TA
Aug 25, 2005 05:10 PM
MysticTeal 95 V6
Apr 30, 2004 11:40 PM
