CSI Pump Wiring
Old Oct 12, 2005 | 03:13 PM
93 4mula's Avatar
CSI Pump Wiring
Whats the best way yall would recommend to wire this pump up? All the people that wire them into a switch do they turn the pump on the whole time the car is running? Or just when it reaches a certian degree? It will be on a street drivin car so whats the best way to go about this...
Old Oct 12, 2005 | 04:20 PM
97FormulaWS-6's Avatar
Re: CSI Pump Wiring
Mine's powered through a 40A relay, triggered off the Fuel-Injector fuse located in the under-hood fusebox.
Thus whenever the key is in the run position, the pump is running.
Old Oct 12, 2005 | 05:01 PM
97WS6SCharged's Avatar
Re: CSI Pump Wiring
I agree with the 40A relay. Mine's setup on the ignition fuse though.
Old Oct 12, 2005 | 05:48 PM
jkipp84's Avatar
Re: CSI Pump Wiring
I used this guide: http://ken.lowrance.com/projects/CSI...mp/Default.htm
Old Oct 12, 2005 | 09:20 PM
slimdawson's Avatar
Re: CSI Pump Wiring
Do not rely on your memory to turn a switch on. It also needs to be on all the time. Might as well be. When your car gets to operating temp, temps would go up in a hurry without a pump.
I have mine on a separate circuit dedicated for it. A wire with an inline fuse coming off the battery post. And a relay with the switch wire hooked to something that is on when the key is in run position.
Scottyboy
Feb 11, 2015 10:28 PM
lbrowne
Nov 13, 2011 04:25 PM
turbo_Z
Aug 19, 2002 10:50 PM
