CSI Pump Wiring
CSI Pump Wiring
Whats the best way yall would recommend to wire this pump up? All the people that wire them into a switch do they turn the pump on the whole time the car is running? Or just when it reaches a certian degree? It will be on a street drivin car so whats the best way to go about this...
Re: CSI Pump Wiring
Do not rely on your memory to turn a switch on. It also needs to be on all the time. Might as well be. When your car gets to operating temp, temps would go up in a hurry without a pump.
I have mine on a separate circuit dedicated for it. A wire with an inline fuse coming off the battery post. And a relay with the switch wire hooked to something that is on when the key is in run position.
stockssn2o
May 25, 2015 08:54 AM
lbrowne
Nov 13, 2011 04:25 PM
turbo_Z
Aug 19, 2002 10:50 PM
