Cruise/wiper/turn signal switch/lever change
Old Oct 2, 2003 | 11:45 AM
Raptor1's Avatar
How much of a job is it to change on a '94 TA? The cruise control has been working sporadic for a while and now it doesn't work at all any more. Wipers and turn signals work fine.
Does anyone know of a web site that may have instructions? Any help would be appreciated.
TIA
Old Oct 2, 2003 | 03:34 PM
You unplug the connector and it is my understanding that you pull straight out on the lever and it will unsnap from the switch.
When you reinstall it, make sure the wiper switch is in the off position.
Old Oct 2, 2003 | 04:11 PM
Raptor1's Avatar
Thank you shoebox. That's fantastic, I really appreciate the help!
Old Oct 2, 2003 | 05:23 PM
RCF925's Avatar
I've done it and it was a PITA, You have to twist slightly and I had to pull so hard I thought something was gonna break, Once I had the old one off I took it on and off a few times and it was easier. If you don't put it back on right your intermittent wipers won't work.
Old Oct 3, 2003 | 07:51 AM
Raptor1's Avatar
So what you're saying is the lever DOES unsnap from the column? You have a '94 Z, which I assume would be the same internally (column) as the TA.
Old Oct 4, 2003 | 06:41 AM
Raptor1's Avatar
Old Oct 4, 2003 | 09:03 AM
Fastbird93's Avatar
IT should just pull straight out. If you had to force it, you probably weren't pulling straight on it.
Old Oct 4, 2003 | 10:19 AM
Raptor1's Avatar
Thanks Fastbird, I appreciate the update!
Old Oct 4, 2003 | 12:07 PM
RCF925's Avatar
Sorry about the delay, I have a spare steering column and I looked at it again, You pull the lever straight out, But when I put it back in I had to spin it around to get the intermittent wiper part to work right, Kinda trial & error.
May 1, 2015 01:14 PM
ad356
Apr 11, 2015 11:12 PM
NJLT1SS
Sep 11, 2002 02:29 AM
Ryabut98
Sep 3, 2002 11:45 PM
