Cruise Control, NOT WORKING!! HELP
my 95z28's cruise control quite working on me, for awhile it keep blowing the fuse for the AC when i would try to set the cruise, now the cruise doesn't even work. Has anyone had this problem or can someone atleast point me in the right direction.
Re: Cruise Control, NOT WORKING!! HELP
Do these cars really have cruise control....
I dont think I have really ever used mine(even on my 9 hour trips home), but thats just the way I drive.
but back on topic I would check all the wires, to make sure none of them are frayed, or melted, or a loose ground. Because to be blowing fuses like that, it will probably be something eletrical
Where does a guy start??
I feel for you. My cruize is kinda like a woman, temptramental. Sometimes it works, sometimes it doesnt. I work for GM, and found a bulliten on it regarding the brake switch. Whenever I start my car with the brake pushed, the cruize doesn't work. If I start the car with the brake not pushed, the cruiize works. Wierd. I would be lost without my cruiz. I like to speed, and with my setup, cops would spend half a day writing me citations. So, speeding is a huge no no for me. Good luck, and give it a try. It may work, it may not.
Oh, and my car is so far from stock its not even funny, so cruize can work with headers, and aftermarket programming.
squarehead
Jan 15, 2015 07:02 PM
