Hotcam Ques
Hotcam Ques
I have the hotcam it self... For now could i install the cam and just get new springs for the lift... Do i need different length pushrods
All the other stuff will be installed in the summer.. Just dont have the money right now and i have to put new springs on it anyway
You should be okay with the factory length pushrods. You can confirm this by checking the rocker tip contact pattern on the valve stem (i.e. valve train geometry). The contact pattern should be centered on the stem and fairly narrow.
