crossbrace
Old Mar 19, 2004 | 07:19 PM
Zachz28's Avatar
crossbrace
In my car i have a black cross brace that goes under the exaust and driveshaft right after the cat. how important is this? and what would happen if i removed it?
Old Mar 19, 2004 | 07:21 PM
PatriotTA's Avatar
I can't see much happening as a result of removing it. It is just a thin piece of stamped steel - it can't do that much. I removed mine but I have a driveshaft loop in a nearby location. If its causing a clearance issue, go ahead and remove it. Otherwise, leave it on there for now. I can't see any gains (even weight loss) from removing it.
Old Mar 19, 2004 | 08:16 PM
ToocoolZ28's Avatar
I took mine off 8 years ago when I replaced the exhaust. No problems in 175,000 miles.
Ron
Old Mar 19, 2004 | 08:36 PM
mobleman's Avatar
Mine came of 9 years ago when I put a flowmaster exhaust on.. No problems. It would be interesting to know the real reason why it was there though, (i.e. NVH, structural, safety etc..)
Old Mar 19, 2004 | 08:54 PM
dnz28's Avatar
it was put there to tie the floor pans together, A little imo that weak crap would flex bad under a side load so buy a aftermarket, make your own, or take it off.
Old Mar 19, 2004 | 09:57 PM
Bud M's Avatar
If you look at the way its made, it is intended to keep the floor from flexing in the direction of "squeezing" the trans. tunnel. If you think it's "weak crap", take it off and try to bend it in that direction. I'll bet you can't.
GM would not have put it in there if there was not some reason for it. Why do you want to remove it? It can't be very heavy. How will your car be better without it?
Old Mar 19, 2004 | 10:22 PM
dnz28's Avatar
I dont think mine will bend its made from 2'' square tube, and 1/8 plate. its still crap.
Old Mar 20, 2004 | 08:49 PM
mobleman's Avatar
Mine was actually taken off by the shop that installed the exhaust. I didn't notice till months after that it wasn't reinstalled..
Personally I'd leave it on....
Old Mar 20, 2004 | 11:51 PM
Zachz28's Avatar
i want to remove it cause my exaust is hitting it
Old Mar 21, 2004 | 10:45 AM
$hawn's Avatar
Put a few washers under it maybe?
Old Mar 21, 2004 | 11:47 AM
T/A#4's Avatar
Stronger one's are made by GMS $149. & they claim it stops body flexing.
Old Mar 21, 2004 | 11:59 AM
Bud M's Avatar
I would figure out how much it needs to be lowered to clear the exhaust, get a piece of aluminum that is slightly thicker and make spacers. Or if you can't do that, use washers likw $hawn said.
Old Mar 21, 2004 | 12:54 PM
CamaroBoy96Z28's Avatar
I believe BMR makes a stronger version of that part too. Instead of being fairly thin, there is a metal tube spanning the trans tunnel. I still have mine in there and dont plan on removing it.
DAVE00
Jan 14, 2011 07:20 PM
Hark_z
Aug 14, 2008 12:43 PM
INSANEZ
Jan 8, 2007 02:59 PM
madwolf
Jun 5, 2005 10:19 PM
OrangeIROC
Sep 26, 2004 03:12 PM
