crossbrace
I can't see much happening as a result of removing it. It is just a thin piece of stamped steel - it can't do that much. I removed mine but I have a driveshaft loop in a nearby location. If its causing a clearance issue, go ahead and remove it. Otherwise, leave it on there for now. I can't see any gains (even weight loss) from removing it.
If you look at the way its made, it is intended to keep the floor from flexing in the direction of "squeezing" the trans. tunnel. If you think it's "weak crap", take it off and try to bend it in that direction. I'll bet you can't.
GM would not have put it in there if there was not some reason for it. Why do you want to remove it? It can't be very heavy. How will your car be better without it?
I believe BMR makes a stronger version of that part too. Instead of being fairly thin, there is a metal tube spanning the trans tunnel. I still have mine in there and dont plan on removing it.
INSANEZ
Jan 8, 2007 02:59 PM
madwolf
Jun 5, 2005 10:19 PM
its still crap.
