Cross-threaded intake bolt--help..
Old Jul 19, 2004 | 07:58 AM
95RagtopTA's Avatar
Right when I started to see an end to this rebuild--this happens. I was "practicing" droping the intake down straight on the block w/o RTV, when I decided to screw in the left front bolt. I started it by hand and cranked on it a couple of times with the socket. Then, it got tight all the sudden and I realized it was cross-threading (must not have had the intake aligned correctly). Of course, it won't screw in now . How do I fix this?? Would a thread chaser work? Hopefully I won't have to helicoil it, never done that before.... Thanks
Old Jul 19, 2004 | 08:04 AM
Re: Cross-threaded intake bolt--help..
If you have enough good threads to start with, a chase should work. A Helicoil or insert is not so bad (actually stronger). At least it is in a place where you can get to it.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
maybe2fast
Mar 26, 2015 08:34 AM
99TransAmWS6
Sep 10, 2002 09:04 PM
