Cross threaded header bolt
I accidentally cross threaded a header bolt the other night. Should I try chasing the tread or should I leave it? The bolt will tighten its just a little sideways. If I should try cleaning it up what size tap is it?
Threads are 3/8-16. That is a touchy call. If the bolt is fully threaded and tight now (crooked), removing it and chasing the threads out straight might make the hole too large and unusable. If it is in a spot where there would be room to heli-coil it, then you would have a back-up plan.
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
