Cross Drilling Stock Rotors Yourself?
Old Aug 9, 2003 | 07:33 PM
lt1_forever's Avatar
Is this possible, has anyone done it? I have a drill press. So maybe someone can hit me back with some info.
Old Aug 9, 2003 | 08:02 PM
LT1Noob's Avatar
Don't do it...if you are not exact, the rotors will be out of balance.
Old Aug 9, 2003 | 08:04 PM
LPEdave's Avatar
Do a search in any autocross/track board for cross-drilled rotors, and have fun reading.
Don't drill them, unless you're just looking to make an interesting door stop out of them.
Dave
Old Aug 9, 2003 | 08:11 PM
Sounds like a good way to ruin some rotors. If not done correctly, you will ruin the temper of the rotor. Even the ones you buy pre-drilled crack around the holes. It is not a DIY job IMO. Drilled rotors won't help you stop any better.
Old Aug 9, 2003 | 11:06 PM
rage366's Avatar
yep.
they'll look pretty, but they wont stop you faster. hell, they'll take away from your stopping power, because you're decreasing the contact surface.
Old Aug 9, 2003 | 11:43 PM
AsianSensation's Avatar
FWIW...I perfer slotted rotors over cross drilled.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
GigaMp3z
Feb 20, 2003 02:57 PM
W7Z28
11
Jun 25, 2002 02:23 PM
