Cross Drilling Stock Rotors Yourself?
Sounds like a good way to ruin some rotors. If not done correctly, you will ruin the temper of the rotor. Even the ones you buy pre-drilled crack around the holes. It is not a DIY job IMO. Drilled rotors won't help you stop any better.
yep.
they'll look pretty, but they wont stop you faster. hell, they'll take away from your stopping power, because you're decreasing the contact surface.
stockssn2o
May 25, 2015 08:54 AM
W7Z28
11
Jun 25, 2002 02:23 PM
