crazy exhuast question
Old Mar 2, 2006 | 07:16 PM
clemsb4c's Avatar
OK I just put on my Pacesetter LT and they are vibrating against my floorboard just alittle but enough to drive me crazy. So my question is can I just stick somthing in between the y-pipe and the floorboard? I was thinking about using a piece of a tire but I wasn't sure that it wouldn't melt so can I do this or should I use something else and if so what?
Old Mar 2, 2006 | 07:27 PM
Hotwire's Avatar
Re: crazy exhuast question
how about checking your engine mounts to make sure they aren't the problem?
Old Mar 2, 2006 | 07:29 PM
2000GTP's Avatar
Yeah, I would start with diagnosing the motor mounts before wedging junk in there.
Old Mar 2, 2006 | 08:01 PM
clemsb4c's Avatar
I'm pretty sure that they OK because I checked them when I put the headers on, its not really the floorboard but where the y-pipe is flatten out to clear the floor brace it touches there when the car is at low speeds or speeding up. So what kind of junk can I stick in there to stop it from vibrating?
Old Mar 2, 2006 | 08:08 PM
Hotwire's Avatar
get a 2x4 and pry on it some to give you the clearance you need, sticking stuff in there will not fix the problem.
Old Mar 2, 2006 | 08:11 PM
clemsb4c's Avatar
Im not sure that there is enough room to get a 2x4 in there. but I guess I could do some adjusting with a hammer.
Old Mar 2, 2006 | 09:13 PM
johnny3986's Avatar
Never underestimate the power of a BFH...
It was got it for me. I know the mounts were good since I just replaced mine.
Old Mar 2, 2006 | 09:43 PM
rcmtby11's Avatar
if the y pipe is what is hitting the floor board, loosen the y pipe from the headers at the collector and put something inbetween the floor and pipe, retighten and remove the something inbetween the y pipe and floorboard. thats what i did. i have shorties though, so im not sure how your headers attach to the y pipe.
Old Mar 2, 2006 | 09:46 PM
jah1542's Avatar
The exhaust on my old V6 rattle against the tranny brace, and I stuck small pieces of tire in there. They'd fall out every few months or so, but it did the job. However, on my Z, I'd want to fix the prob correctly and permanently. JMO.
Old Mar 2, 2006 | 10:04 PM
clemsb4c's Avatar
I want to fix it right but at the moment I don't have the time and until I can put it on the lift I jsut want to rig it up so that I don't go crazy.
Old Mar 2, 2006 | 10:17 PM
nonojoe66's Avatar
mine on my old car did that too i wedged a piece of hose in there a couple of times but it kept fallin out, mine was the y pipe hitting crossmember i took off the y and banged the **** out of the crossmember with a hammer and it was ok after that.
Old Mar 2, 2006 | 10:36 PM
thesoundandthefury's Avatar
Try this:
http://store.summitracing.com/defaul...=egnsearch.asp
Cover it, and cool your engine compartment.
Thermo-Tec's exhaust wrap blankets are flexible heat shields that simply clip over the upper portion of your exhaust manifold or headers. The fabric side faces the heat source for heat reflection, while the aluminized side faces away to offer protection from liquid spills and abrasion. There are sizes for V6s and V8s, as well as four-cylinder and straight-six engines. There's also a 3 ft. x 5 ft. blanket that can be custom-cut to fit your application.
Old Mar 3, 2006 | 10:34 AM
94_PatriotRed_Z's Avatar
alot of us have that same problem, here is a link to a thread acouple days ago talking about some ways to fix it y-pipe hits floor when under power
Old Mar 3, 2006 | 04:53 PM
terrible 1's Avatar
i started that thread...and i ended up bashing the crossmember in...everything worked out just fine. the hardest part was removing the y-pipe.
grabbem88
Mar 18, 2015 01:25 PM
rick350
Mar 16, 2015 02:59 PM
printer61
Feb 27, 2015 07:43 AM
grgguy
17
Feb 23, 2015 07:57 PM
dansam
Jul 20, 2002 01:10 PM
