crap rust
crap rust
i left my lt1 block outside after i pulled the heads off of it...the motor ned to be rebuilt due to spun bearing. anyways the pistons were still in it and it got water in the cylinders i have some surface rust and on the crank lobes, i got oil immediately and rubbed most of it awy but some of it seems to be stuck in the gorrves and crevices of the metal...any tips on how to remove? special chemical?
thanks
daniel
thanks
daniel
Re: crap rust
Do you mean the crank counterweights? A little surface rust is no big deal IMO.. it's got to be cleaned at a machine shop anyways since you spun a bearing.. when they regrind/polish they'll take care of it.
Re: crap rust
Originally Posted by Daniel6718
no it has it on the lobes...in the impurities of the metal
