94z wont start
Old May 17, 2006 | 09:55 AM
camarocrzy's Avatar
94z wont start
I just bought this car a week ago and it ran fine until today. Its been raining for 5 days now and when i went to go to work this morning she wouldnt start. It turns over but wont start. It ran fine all day yesterday,came home, parked,now it doesnt. Can someone steer me in the right direction? Im gonna try to change the fuel filter cause im sure the guy that had it before i did probably never changed it. Any help would be greatly appreciated cause i dont know much about these v8's.
Old May 17, 2006 | 11:44 AM
camaro1fastz28's Avatar
Re: 94z wont start
sound like a distubutor water might have got in there
Old May 17, 2006 | 05:15 PM
camarocrzy's Avatar
Re: 94z wont start
I had it towed to a local PePboys and they called a few hours later to tell me that whenever they went to push it into the garage it started right up everytime. This is really screwed up. I dont think anything got a chance to dry up cause its still raining harder than ever.
Old May 17, 2006 | 05:35 PM
snakeatinZ's Avatar
Re: 94z wont start
sounds like a typical LT1 to me.... Every lt1 I have ever owned has been a jack stand or trailer queen. Dont get me wrong though, when they run they run like a raped ape. You will learn to love that motor.
Steve
Old May 18, 2006 | 01:56 PM
camarocrzy's Avatar
Re: 94z wont start
Pepboys told me its likely the fuel pump. When i turn the key to the on posiion i hear it prime so doesnt that mean its still woking?
Old May 18, 2006 | 02:18 PM
SweetZRag's Avatar
Re: 94z wont start
Not necessarily. The only way to know for sure is to put a fuel pressure gauge on the fuel rail. The schrader valve is located directly behind the intake manifold. It should read around 43psi (I think) and it should hold pressure after initial pressurization by the pump. If it does not, there will be more steps to determine if it is the pump or fuel pressure regulator or injectors.
Start here...
Old May 18, 2006 | 02:44 PM
camarocrzy's Avatar
Re: 94z wont start
It has been starting up for them whenever it heats up a little,but after sitting all night the next morning it wont start. Its cranks over but not start. They said something about they cant use the shrader valve cause the have to check the pressure near the pump or something like that. Does this sound like a fuel pump? Also,would it cost more to have a Chevy dealer fix it considering they know more about GM cars than Pepboys?
Old May 18, 2006 | 02:55 PM
thehunter's Avatar
Re: 94z wont start
That's rediculous. I have checked the fuel pressure plenty of times at the valve. I had similar porblems with my 94. It would be very hard starting on damp and rainy days. The problem was the coil, it was getting damp and causing the hard starting problems. You can pull the wire off the terminal and inspect it, look for white residue. I tracked my problem all the down to water was getting into the fake hood vents, running down the fire suppress thing and dripping on the engine.
Mike
Old May 18, 2006 | 03:43 PM
SweetZRag's Avatar
Re: 94z wont start
Check the coil as suggested and check the fpr as described. Pep Boys doesn't know what they are saying. The pressure can be tested anywhere in the system. Isolating the exact problem will require breaking it down but you first need to determine if the pressure is a problem.
Just to be clear, I am assuming you hear the pump run when you turn the key on. Also, inside the pump is a backflow valve that could cause your problem or the pump itself may not be producing enough pressure.
This may not be your problem at all so start simple by cheking the coil, check for a spark at the plug and check the fuel pressure. This will at least get you looking in the right direction.
I would find a competent mechanic if you don't think you can do the job. Search this site for many tips and opinions on different ways to get access to the pump. Pep Boys does not know how to troubelshoot a car and the dealer reapir rates are too high IMHO.
kksi
Feb 16, 2015 06:49 PM
stopthatman
Feb 9, 2015 09:00 PM
rje
Sep 9, 2002 12:35 PM
FryZss
Sep 3, 2002 03:52 PM
rpmz28
Aug 7, 2002 08:02 AM
