Crankshaft Pulley Bolts Removal?
Old Aug 13, 2011 | 04:53 PM
gtstriker86's Avatar
Question Crankshaft Pulley Bolts Removal?
Im having trouble keeping the crankshaft pulley from moving while i try to remove the 3 bolts. Is there any tips that you guys can give me? Im trying to change the opti. My car is an automatic.
Old Aug 13, 2011 | 05:03 PM
RamAir95TA's Avatar
Re: Crankshaft Pulley Bolts Removal?
Impact wrench works wonders. Or take off the converter inspection cover (4 bolts) and wedge a block of wood in the flywheel (just don't forget to take it out).
Old Aug 14, 2011 | 11:41 PM
JooneJune's Avatar
What ramair said, I use a breaker bar, PB Blaster and a wedge.
Old Aug 15, 2011 | 01:28 PM
boostedz28lt1's Avatar
Im taking it you dont have any air tools?
Well if you put a socket on the crankshaft bolt in the center,this will give you a good grasp on the hub not turning. then break the 3 bolts loose, PB blaster will be your friend if you let it soak for 10 min with a few blast while waiting.
Wedging wood into the converter area is not a good idea in my opinion. But every one has there own way of doing it without the proper tools. good luck with what ever you choose
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
