Crankshaft Pulley
Old Jan 5, 2008 | 08:56 PM
Wild1's Avatar
Crankshaft Pulley
Is the crank pulley for the timing chain on tighter than the hub? I got the hub off earlier with little problem and the right bolts.
But, I'm changing my timing belt and I'm having difficulty pulling the crank pulley for the timing chain. Maybe the Key is jamming it tighter. Is there a trick to pulling the crank pulley? Any secrets?
Thanks.
Last edited by Wild1; Jan 5, 2008 at 09:06 PM. Reason: Clarify crank pulley instead of hub
Old Jan 5, 2008 | 09:03 PM
Stl94LT1's Avatar
What? Are you talking about the lower timing chain gear?
Old Jan 5, 2008 | 09:05 PM
Wild1's Avatar
Yes, the crank pulley. I'll edit the earlier message.
Old Jan 5, 2008 | 09:06 PM
ulakovic22's Avatar
I used a 3-jaw puller to get mine off. Sometimes you can get behind it with a screwdriver/chisel but I just went and grabbed a 3-jaw from O'Reilly's and it came right off. Reason I took mine off was to change the crank key to a 96-97 one so I could install my reluctor wheel.
Edit: Be careful when positioning so you don't snap a tooth off your gear.
Old Jan 5, 2008 | 09:08 PM
Stl94LT1's Avatar
Yep, I used a three-prong puller also.
Old Jan 5, 2008 | 09:11 PM
Wild1's Avatar
Ok, on my way to Pep Boys. I've got a 4" 3-jaw puller and will need a 6" 3-jaw puller.
Old Jan 5, 2008 | 09:13 PM
ulakovic22's Avatar
Why won't the 4" work?
Old Jan 5, 2008 | 10:58 PM
Wild1's Avatar
The reach wasn't long enough. Even after I put the bolts in the furthest holes back. Some have longer jaws, this one didn't.
I just picked up at 2-jaw 6" with a longer reach. It should work. Fingers crossed.
Old Jan 6, 2008 | 12:13 AM
2 or 3 jaw puller should work. Just keep it straight and protect the crank bolt hole.
Old Jan 6, 2008 | 12:58 AM
Wild1's Avatar
Thanks everyone. I got a 2 jaw puller on loan from Pep Boys. The puller threads were not going to mate with the crank threads. So, I put a high-grade washer at the face of the puller to keep it off the crank threads. It worked!!! The crank timing gear came off.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
Slayer
Aug 17, 2015 03:55 PM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
