crankshaft pulley
Old Jan 31, 2007 | 07:17 PM
blondechile's Avatar
crankshaft pulley
i have a 1995 z28 and i have to pull the drivebelt pulley for access to distributor so i can replace the seal. problem is i can't remove the pulley the haynes manual said that no puller is required to remove pulley. i have removed radiator, fans, water pump and associated hoses. but i still can't get pulley off if anybody knows any tricks please help. p.s with out taking the hub off the crankshaft snot would be nice.
Old Jan 31, 2007 | 08:43 PM
When the car was new, all you had to do was take the three bolts out that hold the damper/pulley on the hub, and it would fall right off. But 12 years of rust is what's holding it on there now. A bit of high quality rust penetrant may help, plus a few taps with a hammer (not on the outside diameter), or if that fails, Shoebox has a guide to using a 3-jaw puller:
http://shbox.com/1/pull_pulley.jpg
Old Jan 31, 2007 | 08:47 PM
VK's Avatar
VK
All that didn't even budge mine. Had to use the 3 claw puller.. worked perfect..
Old Jan 31, 2007 | 08:49 PM
OBE1 95Z28's Avatar
It's common for the pulley to stick. Try tapping it with a dead blow hammer. Heat around the center portion of the pulley may also help.
Double check that the opti seal is your leak issue. It's common for the water pump driveshaft seal to leak. the oil runs down the front of the timing chain cover making it look like the leak originates from the lower seal(s).
Old Jan 31, 2007 | 09:13 PM
formula-bird's Avatar
I ran into this today, changing my opti. My pulley had 3 threaded holes so i could put my puller on it and take it off.
Old Jan 31, 2007 | 09:33 PM
ZL1modified's Avatar
no way! Haynes people must be smokin something...
i would love to see one just fall off...
Old Jan 31, 2007 | 10:32 PM
When the car was new, they would fall right off. I swapped out the stock damper/pulley a few months after I bought the car new, and it literally fell off.
Old Jan 31, 2007 | 11:58 PM
SS RRR's Avatar
When mine was new I still had to wiggle the snot out of it to get it off. I gave up after a few years and just started pulling the hub/pulley off as one unit.
Old Feb 1, 2007 | 03:49 PM
KPZ-28's Avatar
Can you tell me what size threads those 3 holes have as mine need to be retapped from the rust and such. I resorted to using 1/4 -20 bolts and nuts last time but I would still like to chase the threads clean. thanks
Old Feb 2, 2007 | 05:43 PM
Thumbs up
I finally got that **** thing off!! I just sprayed a bunch of rust remover on it and wiggled the hell out of it!
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
Slayer
Aug 17, 2015 03:55 PM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
